Mark, what did you use to de-bump strip?
J
on........?F A I L E D
Ball joint covers, exhaust mount snapped(WOOPS) and emissions(wtf?) I have two cats.on........?
Sensor issue mateBall joint covers, exhaust mount snapped(WOOPS) and emissions(wtf?) I have two cats.
Not sure.. To be honest I can't even remember him doing emissions now I think of it. I'm rather confused!what emission figures jordan ?
you need the CO HC and lambda results really mate, else you cant diagnose the causeNot sure.. To be honest I can't even remember him doing emissions now I think of it. I'm rather confused!
Also wondering about the mounting on the downpipe/2nd CAT. I should have got a better look while it was on the ramps, but is it part of the CAT or part of the downpipe?you need the CO HC and lambda results really mate, else you cant diagnose the cause
It bolts onto the cat mate, i have a couple of spare ones if you need oneAlso wondering about the mounting on the downpipe/2nd CAT. I should have got a better look while it was on the ramps, but is it part of the CAT or part of the downpipe?
How much would you want for one?It bolts onto the cat mate, i have a couple of spare ones if you need one
Is it the metal bracket jordan ? 10 posted ? Or is it a broken rubberHow much would you want for one?
Yes the metal bracket. Ok will send over paypal in next 5 minutes. Thanks FrankIs it the metal bracket jordan ? 10 posted ? Or is it a broken rubber
I did wonderDELETE
Don't worry its a bit late to show you?????
does anyone know the thread size of the gear knob? getting a wooden one made for me within the week
Oooooooh pretty!Fitted my rear 2.5" springs, car sits at -60 just as plannedfronts adjusted up, need to be way softer. Plus turbo!
Oh wait...
Air bed pump xD?It's not actually a turbo...
The rear yeah. 2.5" springs sit fine on the bottom without an adaptor, but at the top you need to make an adaptor. I used the spring seat adjuster from a corsa lowering kit bolted to a steel plate with pins to keep it all located properly.Did you fit your 2.5" springs to the rear? Do they fit ok? Or for others that know do 2.25" springs fit the rear ok?
I know it's nonsense but every modern car I've owned has had an outside temp indicator. Therefore I need one in the micra. Just need to fit it now the electrictrickery is done.
WD40 is good at removing stickers, main ingredient is fish oil..
Sent from my GT-I9505 using Tapatalk
Haha. Good god man. Manually adjustable windows. Whatever next.Mine has two outside temp indicators...
....you just wind the handle on the door and voila!![]()
Timing strut!
Going sprinting this season, fo sho'
Where you doing the sprints?
