...and sheet music to recreate all the latest pop hits (eg. Terence Trent D'Arby, Bucks Fizz, etc) with your zorst...
Spose not haha be a good experience though haha, you at a main dealer then or at local?Thats not a bad thing tbh, if we get through the heats, then its off to the NEC never know i might see you there
Hell no! Haha
Nope, just standard mani for F1000. But this is a 1.3 atm so got janspeed manifold.Thought you had to?
1.3 is so much better! Only problem is tyres. With juniors/f1000 it's A048's no matter what, but having to buy wet and dry tyres is expensiveOoh I'll have to get one next year.... last year of juniors for me, then I'll be into the 1.4s too
We bought some A021R's for the wet and they were excellent. Didn't wear too bad either but not cheap!I'll just run semi slicks and for wet just some performance winter tyres I guess
Still, it's better to be forced a good tyre than have a choice of tyres I think!And you can run 8" wheels now? At least there is a bigger range of tyres available
Yep, can't remember the actual price now though. First four and cheaper too!And f1000s get discounts on ao48s don't they?
wish ours did im finished college now :/Thats not a bad thing tbh, if we get through the heats, then its off to the NEC never know i might see you there
I kinda miss writing G-codes and M-codes, not done any CNC in years...
Took her to the jet wash, and cleaned off a ton of mud from last weeks bath festival rally.
Then went for a good thrash to dry her out
Worked out wiring for the dizzy for any of you wanting to use the dizzy cam position sensor rather than those more accurate crank pulley mounted trigger wheels.
Looking at back of plugs, from left to right:
4 wire:
Engine ground
12v +ve feed to optical sensor
Signal feed from sensor
Engine ground
3 wire:
Signal feed to transistor (probably 5v)
-side of coil
Ecu ground
For GA16DE engines treat the two above plugs as one single plug, from left to right on the order read.
Accurate enoigh for nissans engineersFixed that for you
20.3 is not bad for a first run!WDID? Went to crail drag strip had awesome fun deffo hooked on the drag racing
I got 2 runs in as it was mobbed.
With my crappy oversized part worns pretty much on the limit on the First Run against some clio, wasn't really paying attention to what I was against as I had no expectations of winning anyway
Anyhoo with my Meger 1.0l I Manged a 20.3 on the first run with a lot of wheelspin in 1st due to tyres being slick pretty much
2nd run was against @IRNBROO if he still checks here in his Vectra Bus, Thought I had damaged my car as it was whining really badly so I didn't give it all on the second run and got a 21 something
Turns out it was IRNBROO holding it on boost causing the whining noise . Call foul he cheated
I love drag racing, can't wait to have a go.
Aha. You can mess up your clutch quite quick if you're not sure what you're doing, apart from that there's not too much that can go wrong.Cheers man haha, was really nervous I'd mess it up somehow .
Any with crail being not entirely flat I had to have foot on brake clutch it then switch to accelerator. never occurred to me to use the handbrake
That's why hydro handbrakes are ace just let gonever occurred to me to use the handbrake
Didn't say you had to have oneOr put a screw through a normal one...
Nah... why wreck you standard one?
Certainly vivid
Awesome! I wish I was artistic enough to make something this cool... I can do greasy and oily but thats it :/
Oo. Impressive MPH for the E/T.Heres my run time ect taken from the website
Reaction Time - 0.86
60ft time - 2.92
[email protected] mph
