Your attitude is not appreciated. We're trying to save you a pull from the police.wtf is wrong with this poxy site!!!! they are not illegal they are retrofit. #### off with this ####, its always the same knobs aswell
Continue onto a different forum where they accept this kind of language and attitude because I for one do not appreciate it.if you say so. couldnt care less anyways. i get blinded by legal ones anyways. i have projector lenses. fitted. couldnt really care what you all think anyways, bunch of ####ing know it alls idiots
oh well, how do i leave this forum?? i dont want to be part of it any more.
So they're not approved by the DVLA/TUV for road use on a micra then?i want to leave the forum, not just log in. i retrofitted the projectors
Put the induction on half done. Air feed to put on. Went to work finishd n met up wa the micra mate n took pics of our cars like proud micra owners we are haha
Couldn't throw my handbag that farOoooh......saucer of milk and handbags at 10 paces!![]()
You have a handbag?!Couldn't throw my handbag that far![]()
And what?You have a handbag?!
I was seriousi got 1 aswell :S has anyone else noticed that you now get mail reprots too![]()
About ?Random quote @james
@davyboy
I was serious
Fixedfitted the painted steels now need to paint the rest...and take many photos![]()
Manbags I was being sarcastically seriousAbout ?
i try but its dark when i go to work and dark when i leaveFixed![]()
You mean the engine heat will set up a sort of convection of water through the system?with a big enough radiator header the coolant will thermo-syphon anyway andy![]()
That's a bit brave for me Frank! I think that would require relearning a lot of thermodynamics and fluids and some hefty calculations to do it safely, I really can't be bothered to do that either!
I'll make my own electronic controller probably. I like the ameter idea, but if the impellors bust it won't be as clear as a flow meter. Was thinking an electric flow meter with an electric flow gauge of some description... I've got to see what I can get a hold of first. Might end up doing both, makes sense to go belt and braces for something as critical as coolingThere will always be people complaining about things going wrong......it happens to the best of us. I wouldn't let that put you off using an EWP over a mechanical pump. Instead of a flowmeter you could always wire in an ammeter instead, which may be a bit nicer than piping water into the cabin to measure flow.
Still a fair bit of money to lash out, especially if you go for an electronic controller too.
Good thinking batmanWhat about a water pressure sensor... I'd assume the pump would put the coolant under pressure to pump it round?
Electronic controller I'd be looking at the a variable resistor atrached to the throttle/rpm somehow
Pressure relief valves?... and keep the pressure sensor close to the pump output not the engineGood thinking batmanExcept up to temperature the whole system will be at ptessure as the coolant tries to evaporat :/
Pressure should be consistent though around the engine but will be higher by the pump?the coolant pressure is there to raise the boiling point innit, and the pump controller is temperature controlled only
Pressure will increase with flow?Pump is there to generate flow, not pressure.
To a small extent yeah, but centrifugal pumps don't generate an aweful lot of pressure except at silly RPM's, a wild stab on the dark i'd say its likely to generate 3psi or so of pressure?Pressure will increase with flow?
marginally maybePressure should be consistent though around the engine but will be higher by the pump?
I'm thinking purely in terms of being noticeable if the pump stoppedmarginally maybean electric pump needs to full-time coast to feed the heater and maintain heat transfer/flow, and then increase at a certain temperature threshold i guess
Temperature fluctuations based on how hard the engine is used would affect the pressure reading, might be hard to distinguish, though I guess not THAT much more than amps...I'm thinking purely in terms of being noticeable if the pump stopped
What was that phrase againhttp://item.mobileweb.ebay.co.uk/viewitem?itemId=111217782410
Could have a 1no/1nc relay controlled buy this feeding 6v to the pump at low temps (voltage dropped by resistors) and the full 12v at higher temps. One thing I am NOT doing is spending nigh on £100 on an electonic controller!
No = normally open (switch not made in rest position, made when voltage applied to relay coil)Engineers meeting is it ??? English only on here please![]()
