Running spacers will probably add much more stress to the wheel bearings with the offset already -7
adding spacers will reduce the minus off-set, a 20 mm spacer will then give you a +13, which isn't much?
Adding spacers will technically increase the negative offset? Pushing the wheel face further outwardsadding spacers will reduce the minus off-set, a 20 mm spacer will then give you a +13, which isn't much?
Couldn't wait till after winter
That's what the tyre fitter told me. The tyres I took off were 60 profile, and measured 60mm, the new ones were 60 profile but measured 80mm, same as you, its a bit silly.Tyres then. 155/70/15...... mm/ %of mm/ inches.... first number is width in mm, second is a % of the width. And third is inches. 3 smegging different units for one damn thing..... tis crazy.
and i,ve been measuring a pug/citroen mani today andy (the old steel square blacktop cam cover)....................veeery close match too i,ll do some diags later@frank
I've had the polo manifold off. Offered the gasket up to the cg and we have a workable alternative
Cyl 1 & 4 could do with moving in 2/3mm each but that's not exactly hard. Just need to make a suitable flange
That the J4 8valve engine?and i,ve been measuring a pug/citroen mani today andy (the old steel blacktop cam cover)....................veeery close match too i,ll do some diags later
hmm, not sure if it was this, or this mate, the black lower one iirc, the bolts for the primaries were angled like this \ / \ / the same as k11,sThat the J4 8valve engine?
Its good to open more options up... I need to dig out that corsa one now and try that.
I have a spare polo gasket should you want it for further investigation
gonna be the j4 i think andy the ports are a close match look, and 4 of the boltholes should lineup with minor slotting, the other 4 are about 10mm off centre@frank (couldn't quote)
The lower black one is the J4 found in early saxo/106s and later saxo vtr's and 106 gti's etc.
The top one is a jp4 found in c2's and newer saxos etc. My Picasso has a JP4
Got the main 4 to bolt up fairly easily. Do you think those other 4 will be do-able without an adaptor plate?gonna be the j4 i think andy the ports are a close match look, and 4 of the boltholes should lineup with minor slotting, the other 4 are about 10mm off centre
the wheel bearings are already inboard of the hubface 40mm ish, so the stock wheels bring the wheel centreline roughly level with the bearings centrelineRunning spacers will probably add much more stress to the wheel bearings with the offset already -7
If is only a leak betqeen c/c and coolant pathways would give those symptoms
the coolant level will be the clincher matt, if its not drinking coolant its fine
Combustion chamber Mattsorry to sound thick but been racking my tired brains whats a c/c?
the 2 bottom holes could be re-drilled on this type eh or else separate/cut the flange into 4 individual runners, then tweak them ?Got the main 4 to bolt up fairly easily. Do you think those other 4 will be do-able without an adaptor plate?
cheersCombustion chamber Matt
Ah yea. It has a full plate at the bottom which is a bonus, cutting and tweaking the runners could help match them up perfectly to the portsthe 2 bottom holes could be re-drilled on this type eh or else separate/cut the flange into 4 individual runners, then tweak them ?
aye forgot to link that mani btwAh yea. It has a full plate at the bottom which is a bonus, cutting and tweaking the runners could help match them up perfectly to the ports
Jus getting one now and giving it a go
Not a bad price eitheraye forgot to link that mani btw
http://www.ebay.co.uk/itm/CITROEN-S...arParts_SM&fits=Model:106&hash=item5aee54d25d
also forgot to measure the height of that saxo engine today (to check for sump clearance)
NO !!!!! I have themFitted wind deflectors to the road car.
Am I a **** now or not?
That's interesting Joe K, I want them there blue dials on my motor. I assumed the tacho would work just by plugging the adaptor in the back, is that not so ?????Wired up my tacho on the super s dials. Fiddly and annoying, especially with no light after half way through. Seems to work though and means I don't have a pointless gauge sat there doing nothing now
I believe yours is a coilpack model no? 1.4? Yours will be electronic speedo and tacho. These dials on mine are pre facelift so manual speedo. The only reason i had to run extra wires is that my car is poverty spec on a diet so the wires simply werent there to be used.That's interesting Joe K, I want them there blue dials on my motor. I assumed the tacho would work just by plugging the adaptor in the back, is that not so ?????
Fitted the primera 1.6 air box. Its fantastic! removed the baffle in the top lid and not used an intake pipe - the noise is awesome and revs feel a lot smoother. For a £10 scrap yard bargain I fully recommend it as the first "mod" for anyone looking to upgrade their cars air box.
Noise just tends to mean the engines working harder to pull in air... Sounds cool though
Morning all. Does anyone live near Woking, Newcastle upon Tyne or Crewe areas?
If so can you message me. I've a favour to ask
Not really just today but over the last few days, just been too manic to update daily...... But here is the start of the WRC Wales Rally GB Prep
I do. WokingMorning all. Does anyone live near Woking, Newcastle upon Tyne or Crewe areas?
Yep the CGA3 engine is in and is running a Nistune board ECU, off to be mapped next Tuesday at Ed's.
Unlucky mate :/ don't worry, won't be long.. Still shorter than me, aye?wooo failed my theory for the 4th time, even longer before i can drive my micra legally
Same as before Chris?wooo failed my theory for the 4th time, even longer before i can drive my micra legally
