WDIDT?
Cleaned her quickly then took some photos. My favorite one:
Not so much tyre pressures but does the cold affect suspension? For example does shock oil thicken with the cold or rubber bushes get harder? My car feels harsher in the cold weather, seems noisier too, creaking and squeaking.Did my tyre pressures as my front drivers was looking real bad. It was down at 13 psi. No idea if its a puncture or just the cold getting too it. My other tyres had all dropped by about 4 psi too! Crazy stuff. Anyone else having trouble with tyre pressure in the cold?
Do a leak test Harlen, bottle of washing up liquid with water, and put solution on both sides of the bead and the walls and tread of the tyre. You will see bubbles forming where there's a puncture etc....Did my tyre pressures as my front drivers was looking real bad. It was down at 13 psi. No idea if its a puncture or just the cold getting too it. My other tyres had all dropped by about 4 psi too! Crazy stuff. Anyone else having trouble with tyre pressure in the cold?
Harlen said:Did my tyre pressures as my front drivers was looking real bad. It was down at 13 psi. No idea if its a puncture or just the cold getting too it. My other tyres had all dropped by about 4 psi too! Crazy stuff. Anyone else having trouble with tyre pressure in the cold?
Mine was leaking for months, sometimes about 4psi per day!Jay and Scott cheers for the replies I'll definitely do that tomorrow!
lee k0011 said:Failed it's mot![]()
Sorry to hear. What did it fail on?Failed it's mot![]()
Needs a new front cross member and a inner sill repair..Sorry to hear. What did it fail on?
Not too badNeeds a new front cross member and a inner sill repair..
Just need to find some one who can do it now.. Struggling to find a descent welder round here!Not too bad![]()
Its not mine ... Sad times. But I get to drive it a lot yay. No doing some work on it for a member here. Just think .. A year a go my ability with mechanics was changing wiper blades.I want oneyou have too many lol
Lol. Are they all the same then? What's the big bearings called and the odd cone shaped , with little cylinders instead of bb's?i have some spare ones chrisi,ll send them with the bushes
not on a road where police have hiding spots lol
true mateI'd say its a reasonable excuse if you were trying to avoid crashing![]()
Might be reallllly heavy... Laden with gold bullionIf you almost beat a 260+hp Boxter then they weren't trying and you probably embarrassed yourself.
Sent from my GT-I9100 using Forum Runner
skymera said:If you almost beat a 260+hp Boxter then they weren't trying and you probably embarrassed yourself.
here,s what bearings i can get off chris, the ballbearing 1st motion shaft one (near the clutch) the needle bearing off the other end, and the 2 outer cones from the layshaft and shims (cant get the inners off without busting the roller cage)Lol. Are they all the same then? What's the big bearings called and the odd cone shaped , with little cylinders instead of bb's?
well sit on my face and call me terry
Frank you are a nightmare! He is buying them, you will need these with all your projects! I do appreciate it but you don't have tohere,s what bearings i can get off chris, the ballbearing 1st motion shaft one (near the clutch) the needle bearing off the other end, and the 2 outer cones from the layshaft and shims (cant get the inners off without busting the roller cage)
