Firstly thanks to Kristian for thinking of this good idea of a forced inuction thread and thanks to kev for putting it up.
As you all know i have done the CG10DE turbo conversion, some of the reasons for this was the insurance and i have the choice to upgrade internal parts to make it a CG13DE turbo
Only issues my tuner had with this conversion was the fact that he never did a micra before as he does all major jap peformance cars and its threads like this that gave me knowledge to pass onto him and make the converison more clearer, his words was 'it just such a great little engine and such a simple setup wich works great'.
Hope this information is useful for when u are thinking of turbo charging your CG10DE and if you require anymore detailed info such as the compression rate then please reply on this thread and i can answer your question, but some things may be the same as the cg13de conversion so anyone else with a k11 turbo conversion can easily answer them.
Pictures:
Make and model:
1994 K11 Nissan Micra Tropic (998cc twin cam 16v-CG10DE)
Engine Modifications:
Full engine rebuild
T20 Turbo bolt on kit
Down pipe
GA16 injectors
CG13DE Cams
CG13DE Pistons
Front mounted intercooler customized to fit
New cam chain
Oil Catch tank
Customized battery tray and smaller battery
Denzo iridium spark plugs
180SX Fuel pump
Nismo engine mounts
Custom made paddle clutch
oil catch tank
oil lines
induction kit to suit setup
colour coded rocker cover
G-reddy emanage blue ecu
Alloy piping and samco hosing
De-cat
Janspeed mid section
JDM imported rear silencer
Handling Modifications:
Spax vrx coilover kit with adjustable camber
Omp front upper adjustable strutbrace
Whitline rear adjustable panhard rod
Standard micra brakes (Almera n15 setup waiting to go on)
Exterior modifications:
K12 factory bodykit (Sideskirts-corner splitters-arch trims)
Ibiza gti rear splitter
K11 Super ‘s’ rear spoiler
Front bumper smoothed with grill cut out
Rear bumper smoothed
Front upper grill modified to ‘open mouth design’
Tailgate smoothed and de-locked
Blitz vision alloy wheels fitted with 195/45/r15 tyres
Interior modifications:
80% stripped interior
Cobra clubman bucket seats in black vinyl
Color coded parts of dash
C13DE raised gear surround
Carbon fiber door cards
Gear and handbrake gaiters
Auto gauges (oil-water-volt-boost)
Sparco 4 point harnesses
Door handle and winder sprayed black
Omp steering wheel and boss
Cost of turbo conversion including buying all parts and the labour and setup was £3500
total cost of everything so far is £11,000
