My wife's 1.0 K10 (K reg) sprang a leak and it seemed to be coming from underneath the carb. I took off the air filter and as the hoses were OK I deduced it was probably coming from one of the two joints between the carb and the inlet manifold. I wasn't even aware there was water circulating there and my Haynes manual is a little sketchy on the topic. Anyway I popped them off, cleaned up, and applied some red instant gasket. I have been letting it set overnight and now... I am wondering if I should have used a proper gasket instead. Any views? Thanks.
BTW this is the second leak it has sprung.. it ruptured a top radiator hose a couple of weeks back... and I am now wondering if I have an underlying water pressure problem.
