hi all,
i have a shed of a volvo 940 which i am trying to sell,
but it has a problem, it wont start. it starts every time if i bump it, but if i use the key it usually doesn't start.
it has brand new spark plug leads and plugs, the plugs are sparking fine, the fuel pump works and i have fuel at the rail, i also have a pulse at the injectors, the plugs seem to be dry but the fuel could have evaporated before i got them out.
the battery is brand new and fine, the starter motor engages with the engine and turns it fine, all relays and fuses are fine, the ignition barrel has also been changed.
if i turn the key to engine ON mode, and then start the starter motor manually by running a wire to the battery it doesn't start, but if i roll the car forward it will.
my theory is that when the starter is running it is taking too much power and the car wont start which is why it works with a bump but not on the starter. i am thinking it might be a bad earth,
i have checked all earths to the engine, redone the main battery earth, i have taken the ECU apart and reflowed it, it looks fine.
so i am totally at a loss now, i cant think what it is, but no one will buy it if it wont start.... crappy volvos!
