vented discs
My micra has vented front discs, can you get these specifically for a micra?, or are they likely to be from another car. With this in mind are the calipers likely to be non standard too? or will std calipers fit with vented discs, i cant compare cause i dont have a set of std discs.
thanks in advance!
the last of the line k11's (00-03) had vented discs fitted on some of the 1.4's and the auto's
Shouldn't be too difficult to find. Measure the thickness and diameter and get Googling :grinning:.
thanks yeah iam going to check when i get a chance, i was told today that auto micra's had bigger calipers is there any truth in this?
the vented setup i saw on a 1.4 had the same size pads and same disc dia as non vented ones, but the calliper is sure to be wider to accommodate the wider disc tho eh
