Dont expect it to work perfectly however..
Keep the same ECU - if not you'll have to go to Nissan for them to disable NATS, and that won't be cheap!
using the 1l ECU may even make the run a little bit sweeter.
the ecu's are the same, the only diffrence between a 1.0 and a 1.3 is the engine size's.
i dont think you will have any trouble with the ecu or nats when changing engines over. when you have changed the engines over you may need to get your key fob re-coded at nissan. this depends weahter you disconnect the battery or ecu i think not sure.
or to be more specific just the con rods and cams
