I wish to know which bit your one aboutsound advice there ^
I am a cheap ass south east man....???? that count? yeah no play, mean go play. Bitches love a solid shaft with no give initDoes it spin up ok? Any shaft play? May be worth giving it a go 'as is' and taking it from there. Cant you tell I'm a tight ass yorkshireman!
Ha ha, dont start me on the north/south divide!I am a cheap ass south east man....???? that count? yeah no play, mean go play. Bitches love a solid shaft with no give init
Ah, sorry, didnt realise you needed to clock it. Thought you just wanted to make sure it operated correctlyI would give it a go as is......but need to reconfigure it so the oil feeds are pointing the correct ways.....but can't budge the thing
Or jus buy another second hand turbo
Aaaaaahhhh
Everything's all coming together, and parts are being made to suit this turbo, (or another like it)
Gotta start building all parts up soon and want everything in working order before I do
Sent from my iPad using Tapatalk
south side is de bestHa ha, dont start me on the north/south divide!
Clocking is easy enough, unbolt the waste gate bracket, using some good quality circlip pliers remove the big circlip (on the inlet side) turn the turbo to where you want it
nah, paul is the turbo rebuild expert, i just shelve the knackered one and try another turbo lolAll together now.............."FRANK!!!!!"
if it wont budge after a week soaked in thin oil, i think i would give up personallyYup, got that far, will it turn...... Nope, I'm no wuss when it comes to 'persuading' things either
Odd would seem we have two different exhaust housings
Clean it up and re build it, good t2's are getting thin on the ground
I could wiggle it a bit from side to side, but I have no basis of comparison as this is the first turbo I've had in my hands
So kits are only £50 , so that plus the £20 it cost to buy, still less than most other turbos out there
But how long would it last? :/
a new core is an option http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=t2+turbo+core&_sacat=0&_from=R40 but i would clean it out and try it to see if you can get the project running first (before it turns into a moneypit )New turbine shafts are £75 ish
So £75, £50 kit...... Hmmm
Spose it's cheaper than a professional rebuild. If I do it right
Or stop being a tight ass and look for newer one
