solarice
CA18DET Throttle Body : £20 ? +p&p
Might be useful for running a bigger intake (think it would need an adapter if planning on fitting to manifold directly). This is just the throttlebody, so maf etc would need relocating / acquiring. Similar to using the sr20 TB.
I think the inlet is something like 56mm (manifold side)...with a 69mm (filter side)
GA16DE Throttle Body and Modified ECU : £40 ? +p&p
Throttle body has had the un-needed ports cut / plugged and the ECU has, ive been told modified so the wiring is correct (one pin rerouted/swapped out iirc). Ive had this awhile just sitting around boxed doing nothing. Can't say much about it as i never fitted / tested it, but it seemed to work when it was on the original owners car (old member from here)...after all thats why i bought it haha.
Doubt i'll be fitting the GA16 TB to mine, so may aswell see if anyone can make use of it.
Gimme a PM is you've got any questions or want pics, wanna haggle etc etc
