Hi guys,
I've seen a few threads on fuel economy, and a lot of advice given is to check the car mechanically (full service, O2 sensor etc). The other point is the way the car is driven. Obviously ragging the car at 7,000RPM isn't good for economy or the engine, but is running at the engine low RPMs by changing up too early just as bad for economy?
I got into the habit of changing at around 2,000RPM (higher if I wanted to accelerate faster), but my economy still isn't that great, so I guess my habits aren't doing the car much good, putting more strain on the crank/gearbox/clutch etc. Is there an optimum engine speed for changing up on a CG10DE (for economy and performance separately), assuming I'm on a flat surface etc?
Many thanks!
Many thanks!
