Updated my blog, got rid of a lotta sh** to make the whole thing a bit more concise. The original version of this post is July 2017 but it is now June 2019 and I am updating.
Owned the car since June 2016 so its been 3 years. Here's what I have done so far:
Performance:
1. 1.4 Inlet Cam - Made a HUGE difference to the power. Gear 3 felt like gear 2, so much more torque, well worth doing mod. I stuck with just the
inlet, as putting the exhaust cam in as well pushes the powerband way too high for my liking. So I reverted back to the stock exhaust cam. For
reference, stock 1.0 cams are 196 deg, 5.56mm, 1.4 cams are 222deg, 7.46mm.
2. GA16 Airbox and CAI Routed to Front Grille - Made the throttle slightly more responsive and a slightly nicer deeper note.
Interior:
1. Painted Quite a Bit Black
2. Blue Interior Lights
3. Rev Counter Instrument Cluster - gotta know what rpm I'm doing dude.
4. Full Sound System - Pioneer 4-Way Door Speakers, Standard Speakers In Parcel Shelf, A Pillar Tweeters. It already had a nice Sony Xplod headunit.
Exterior:
1. 35mm Lowering Springs - One of the best beginners handling mods; a must have mod, it reduces body roll so much and of course is slightly
pleasing to look at a lowered car. A before and after is below.
2. White Sidelights, Headlights and Registration Lights
3. Black Headlight Inserts - Joey Mod
4. Wheel Spacers - Fat ones at the back along with 185/55/14's. Really wanted aggressive stance, so I went and got it. Extended studs were required.
5. Painted Brake Calipers and Drums Blue - don't really know why since the trims cover them up anyway, but I'm sure blue calipers give 5hp!
6. Sprayed tyre shine on all grey exterior plastic trim, makes it look like new, although has to be done roughly once a month. Works well on black trim as well e.g side mirrors, tailgate handle, scuttle panel.
7. Chrome Surround Rear Registration Plate - Removed this eventually.
8. Retro Style Center Caps - Removed these eventually and put the standard Nissan wheel trims back on.
I am keeping the exterior pretty standard apart from these subtle mods.
Here's some photos.
