Well its been a short while since anything too exciting happened. Few LITTLE things:
1. Toyo Proxes CF2 - I can confirm these are an excellent choice of tyre. The grip in the wet is so strong and they are amazing in the dry as well. No more wheel spinning in gear 2 (and 3 in the rain!). I have had new (budget) tyres before and can solidly confirm they were no where near as good as these Toyos. And for £60 a pair they aren't exactly much more expensive compared to getting new budget tyres.
2. Painted Front End - Although the original plan was to colour code the front, I decided to go for black instead. I resprayed the corner bump strips in BW3 green and then the inside of the grills, and the grey bumper trim in gloss black. Makes the front of the car look new and fresh - you wouldn't believe it's a 17 (nearly 18) year old car!
3. Sanded Rocker Cover Nissan Lettering - I love this mod, as its so simple and quick to do but the results are amazing! Could do with a clean though.
4. Upgraded Horn - The old, and frankly tragic horn gave up and so got a truck air trumpet horn which wasn't compatible for boring reasons, so got an OEM-looking Bosch Fanfare horn. It may look OEM but it doesn't sound OEM at all! It sounds very similar to the truck horn. The original K11 horn plug fits straight onto the positive connector and a ground needs to be attached to the negative connector.
5. Edge Subwoofer + Amplifier - Although this adds weight which I am not happy about, it sounds AMAZING! It has a built-in amplifier and enough bass to shake the ground.
6. ITB Conversion - My mechanic has been really busy and so not managed to make me the inlet manifold and airbox for the throttle bodies. As I want to do the bike throttle body conversion asap, I have ordered ready-made parts from eBay, DanstEngineering, Boggs Brothers and Demon Tweeks:
- Boggs Brothers Micra Inlet Manifold for GSX600R Bike Bodies
- Danst Sillicone Hose Fitting Kit (to secure the throttle bodies onto the inlet manifold)
- Pipercross PX600 Airbox + Filter + 100mm Intake Pipe
- Pipercross GSX600R Baseplate
- Adjustable Fuel Pressure Regulator
- Micra K12 Injectors
Will upload photos of these as they arrive. Danst has a 10 working day lead time and will probably be the final arrival.
In the meantime, I have started to strip away all the unnecessary stuff from the bike bodies. Hopefully I haven't removed anything that I needed!
7. ECU Remap - I called Tornado Systems today; what an absolute legend Mark is, so helpful! He's requested I send him as much info on the throttle body build including photos of inlet manifold, airbox etc, and then they can start to look into making an optimum map for me. The way it is going, they will be able to remap the ECU by post and provided I give all the right information, they will be able to do a pretty damn good job.
And yes I am that idiot that has reg plate bulbs so bright that you can't even make out the reg plate letters anymore!
