testing a distributor + diagnostic software
hi all , my sisters son has a 1litre year 1999 micra, its only done 30k and its in a1 condition.
however it cut out and now wont start, i have tested for a spark at the plug and between the cap and a plug lead and there isnt one, I have tested that the low tension circuit is getting power and it is., i assume thats the connector with just 2 wires.
i assume the above tests prove that its a distributor fault. is there anything else on a micra,
also what diagnostic software do you use, i have vag com for my passat
Hi,
I am using Torque Pro
Regards
