CMF_queazocotal
» CMF MemberI've broken several fastners that hold bits of the interior trim on (notably the trim behind the central pillar, over the ECU and the wheel arch liners).
These are black, ~20mm diameter, with a rounded head, and a 6mm diameter 1mm depression in the middle.
I don't know what the back of them looks like, as I have not successfully removed them.
What's the correct procedure for removing these, and what are they called, so I can track some down.
