CMF_daily_ricer
» CMF MemberHi all,
I've just received a whole bunch of polyurethane suspension bush kits for the front and back. My front and rear wishbone bushes are worn due to power steering leaks dissolving the rubber, so I thought I may as well replace the whole lot now the power steering is fixed.
Having never done this before, I googled how to remove the stock rubber bushes.
http://www.timskelton.com/lightning/race_prep/suspension/urethane_bushings.htm
The link above pretty much says my weekend is over and it will take me more than the afternoon I originally planned.
"The whole process took me about 20 hours, evenly divided between the burning, the prep, and the install. Between the messy burning rubber and the gooey urethane grease, the job is most unpleasant."
I had figured the stock rubber stuff would be pressed in there pretty tightly, but wasn't expecting to have to blowtorch may way through it all then repaint bits.
When I search on CMF, I only find posts where people say they have "replaced front suspension bushes", and no hints tips or guides.
So to those who have done it them selves, how have you done it???
