right i took my airbag steering wheel off to see if i could fit a super s steering wheel but it would not fit i put it all back together and now the indicator dont click off anymore when i turn steering wheel back after a corner any ideas how to fix? Thank Joel
did not see any blue pins i want the super s wheel on really it has no airbag but when i took wheel off and a plastic bit there were a role of white wire or sumet any ideas what that was anyone?
so youve removed the rotatable disc (has lots of writing on it and a connector) somthing about a waring on it...iirc. as thats the airbag / horn connector bit...and will get in the way if thats still on...
The white wire you mention im slightly unsure about at the moment...
if fitting a non airbag wheel you will need the horn/indicator cancel parts from a non airbag car, just so you know
the spool on the airbag wheel MUST be centered when you replace it, or you will rip the tape/wire off (you turn it anticlock then turn it clockwise, counting the turns, then set it half-way
fitting to non airbag isnt hard, just time consuming...just had a look about on here for an old reply i made before, theres a rough explanation of whats involved (the link below will allow the auto cancel and horn to work as it originally should...you can also see the blue disc i was referring to earlier)
