starting issues
I need help, i had starting issues with the micra (1.0 coilpack) I've changed the alternator and starter motor but the car still doesn't turnover.
battery is reading just over 12v, maybe its lost the guts to turn the engine over??? Any help asap please!!!
Yep there's power going to the starter motor.
what cold crank amps does the battery need to turn the micra over???
I had this exact problem when fiddling with the battery. Wouldn't turn over but there was power to starter. Turned out it still was the connection to battery. Was too weak that it wouldn't turn over. Not sure about amps
Just disconnected the starter motor and i can here the engine sparking. Do you think its because there isn't enough guts in the battery to turn it over???
