Can anyone tell me the factory height of the CG cylinder head?
Cheers
Paul
Cheers
Paul
Planning a skim job / porting/ build ? I am planning on this in the summer, hopefully found a CGA13 up north collecting it in July if it all works out.
121mm paul![]()
a 1mm skim should be level with that square stump underneath paul, and a 2mm skim will shave the top off it
i think a 2mm skim is about 11.5, like the 1.0 piston mate
i ran a 2mm skim for a while matt, the only issue is the slack lower chainSounds good to me, so a 2mm skim seems like a good starting for a high comp build, using a stock CGA13 bottom end with standard pistons is this viabale ?
i slotted 1 of the chain guides to take up a little bit of the slack, its low revs that have an issue really mate (spark and cam jitter @ idle)Ok thanks, is there anyway to take up this slack? Does it cause any real issues bearing in mind this will be an engine recieiving a lot of abuse and high revs?
there,s no easy solution with the CGA,s matt, because of the huge dish in their piston, there is some info on the corsa mod half way down here http://www.micra.com.au/community/message.php?messageid=69926.Ok i may start at 1 or maybe 1.5mm to start with.
