I have used a top quality ma10 gasket and they are pretty much the same except for dimensions.I used an oem st from nissan on my own car as they were still available 2years ago still sealing perfect.I would choose nissan parts as best i could everytime. Most st owners cant be bothered payin nissan pricesThey are made of cheese.... OEM ST ones are much nicer.
ok cheers
Ed im in trouble then lol
id put my neck out and say most of the figaro ones you buy off of ebay and similar places, if there not oem ones there for just a standard ma10 ones branded as figaro and at double the cost.
ok cheers
whats the options regarding gearboxes? are the st drive shafts and cv joints different to the normal k10 and k11?
i would have thought that a cg13 gearbox could be used, along with some hybrid cg13/st driveshafts? i.e. cg inner cv joints, and st outers? or even put a whole k11 front end on it like hubs etc then the cg cv joints can be used?
He wont tell you weather its the same as the st steve.imp124;37148tut2 said:yeh i mressaged him about it just to confirm it is... looks like this will be the way forward and an expensive month![]()
Is your head gasket blown, Steve???
think so
Mate, I don't want to sound like devil's advocate here...but...
I was always under the impression oem ST headgaskets fail around 160bhp. That ST was advertised on ebay as 160bhp. With an old stock headgasket, as far as we know. ST headgaskets are near extinct. If that 160bhp was achieved largely by increasing boost then you are functioning on a hotter burn in your chamber, which won't help matters.
It was irresposible for this car to be tuned so the headgasket was being pushed so close to its limits. :suspect:
Bottom line, an engine is only as good as it's weakest part. So from here you can:
a) get a much tougher custom headgasket
b) tone it down immediately and hope it improves
c) replace the gasket with an MA10T gasket and tone it down.
Your car appears to be set up very nicely to extract its full potential, you just need to be realistic about what that potential is...and currently it is over that potential...just my opinion :wasntme:
It won't be 160 and i'd be amazed if it blew for power reasons. (If it has that is)
i never got a box from baz in the end
its got a weak spark now and wont start at all, i have changed the plugs, ht's checked, changed the coil as the super s has the same part number, cleaned contacts on the dizzy and rotor arm, run out of ideas now guys. the spark occasionally fires and when it does its an yellowy spark
any common sparking problems i have not thought about?
plugs have been changed, i have put in new plugs with the same code on that i took out, NGK (BCR8ES) does this sound right?
really getting a bit down about this now, nothings going right![]()
