right, bugger it.
i did it myself. lol
no idea how much a nats ecu loom will effect me woring in a non nats ecu...... but.. i can but try eh?
1994 k11 micra vs 1994 p10 primera ECU positions.
1 r/y transistor ignition
2 l/b tacho tacho
3 w/r resistor ignition signal check
4 w/g relay eccs relay
5 blank instrument cluster
6 B eccs ground
7 w/l diag consult data
8 imobiliser ...
9 rad fan r/w cooling fan
10 blank ...
11 air con
12 coil ignition blank
13 eccs ground
14 diag r/w consult data
15 r/b diag consult data
16 w/g maf maf
17 maf ground
18 r/g coolant coolant temp
19 lambda w/y o2 lambda
20 w/l TPS tps
21 b/w maf sensors ground
22 w lps cam position sensor
23 y/r consult data
24 mil mil (check engine light)
25 ...
26 imobil p/b ...
27 l/br knock sensor
28 tps for auto control
29 maf b/w sensors ground
30 w cam position sensor
31 w cps cam position sensor (ref)
32 y/l speed speed sensor from clocks
33 p/l rear window/ headlight signal
34 g/y fuse start signal
35 or neutral neutral
36 w/b ignition switch
37 g tps tps power supply
38 g/w relay ecu power supply
39 b eccs ground
40 cps w cam position sensor ref
41 y/r air con
42 l/g ...
43 gb power steering oil pressure
44 ...
45 heater blower lg/r air con
46 fuse y/b back up power supply
47 relay g/w power supply ignition
48 b eccs ground
101 g/y injector 1
102 ...
103 l injector 3
104 b/y pump ...
105 b/lambda ...
106 b/y pump fuel pump relay
107 b eccs ground
108 b eccs ground
109 current return
110 l/r injector 2
111 idle iac l/y heated lambda
112 br injector 4
113 idle br/y iacv acc valve
114 evap canister purge valve
115 ...
116 eccs ground
