if you own a pre facelift k11 1993/97 then yes. You may have to run 1 wire from the dizzy to rear of clocks depending if the wire is present or not in loom. I can mark the rear of clocks with marker pen so you know where to connect it to...
all 1.3 k11's have the loom ready to accept these clocks, not just the GX. They worked straight on my LX which iirc is the lowest trim you can get for a 1.3
