Spraying Trim
Tom 1.0
Hey,
I'm planning on colour coding my platic bumber, grill and door handles, i've got a Red (AJ4) K11 (facelift)
I've got the right primer, AJ4 red and clear laquer, but i was just wondering, how much sanding do i need to do on the trim parts,
do i need to sand it down at all, or can i just prime it and go?
hope that mekes sense, and advive is greatly appreciated :)
cheers
Use 600,800 and 1000 grade wet and dry and you should be fine :) As long as the grain on the plastic is gone and smooth,will be fine to spray over :)
You removing them off the car? Or spraying them on the car?
if i can figure out how to get the door handles and grills off i will,
but i'm leaving the trim on the bumper, just planning on covering eveything in tape.
thanks for a quick reply :)
Take the door card/panel off and you'll see 2x 10mm nuts holding the handle on. Theres a piece of metal rod? attached to the handle,you'll need to un-hook that and the handle will come off :)
