spacer kit 32mm suit any micra k10/k11
kristian
One Way Mule
This is a re-bolt spacer kit to suit any micra.. they suit any 4 stud from 94mm to 118mm...pcd..
They are 32mm spacers so are 32 thick obviously... they are Re-bolt spacers ... so each spacer comes with 4 bolts which bolt onto your existing bolts, the spacer sits over the top... then you put your wheel on and use your original nuts.
This is a pack of TW0!!!!!.. so only suitable for 2 hubs....
this pack contains 8 bolts and two spacers...
Ive run these for a year and are in PERFECT order.. ZERO vibrations...
'GRAYSTON branded'
( They are just like these...
http://cgi.ebay.co.uk/32MM-1-25-WHE...050183409QQcategoryZ27377QQrdZ1QQcmdZViewItem )
sending on monday mate.. have had some probes getting some free time during the week... could send these also?
7 pounds? plus 3 P&P?
you want to watch out here. I've heard of reports that if your wheels are sticking out more then your arches, you can be fined for this.
yer i am going costum arche's i am haveing 9" wide weels as well !!!!!!!!!!
i am also looking at axel extentions but these will do for now!
i want a wide micra!!!
You been given some inspiration by mine?
You will need to pick up another pack to cover the other axle...
but there cheap enough of ebay.. Or i can supply a number I got mine from..
the reason its only one pack is that i still runs spacers on the rear..
So have a spare pack..
each pack is suitable for both front and rear btw
yer i was going to get them off ebay!!
i will take them!!!! but cant pay now i will do it later vie paypal yer!!!
can you post mate? and double checking, these are the right ones to space the wheels out for the REAR wheels. on dusks old wide arch k11 remember.
i they should be fine, stew hows it coming along anyways? aint seen u on c4f for a while,
