and the premier one:A Standard API Engine from Japan is one that will have covered less than 40,000 km's.
I've heard good stories about them beforeThe 'Premier Engine', having passed all the regular standard tests is then connected to a purpose built rig that will allow the engine to run for about 45 minutes. Because it is connected to a full water cooled radiator system its hot running characteristics can be evaluated and its oil pressure and compression performance can be very carefully monitored under more usual circumstances.
A new cam belt is fitted before testing and after the engine has passed the test, all ancillary components, that are usually supplied attached to a standard unit, are removed and discarded. Franchised dealers are aware of the fact that to prepare a standard A.P.I. engine for fitting can require up to an hours work. With labour rates in some parts of the country approaching £45.00 per hour this is obviously a sensitive issue. By supplying an engine with all gasket surfaces clean and the block ancilary free, the worry is overcome.
Dear Paul
Thank you for your interest in API Engines Ltd.
We have that engine in stock for you at £495.00 as a low mileage used imported engine
Please look here for all the specs of an engine from API. Please take careful note of our
warranty and also how our products are achieved and presented.
The engine will cost around £34.00 to freight to most England postcodes. We do not need
an exchange unit.
If you are in the UK please add VAT [ Sales Tax ] to all quoted prices.
If you need more information or I have missed something, or you wish
to place an order, please call the sales line above.
Thanks and kind regards
David
APi Sales
James said:Or you could try www.findanengine.co.uk - They contact a load of scrappies for you, it's where i got my last gearbox from
James said:Yeah sorry to clarify i didn't mean it was expensive for a recon, i meant for just having a second engine to play with :blush:
James said:I was talking about wilsonian! And also it wasnt the manifold, it was the backbox, which actually needed a breaker bar to get the bolts off, which i dont have, and a set of ramps, which i also dont have
At the end of the day, I preferred paying £23.50 for a man to do it in 20 minutes than for me to get cold, wet and strain my back (amongst other things) most probably.Ian said:ive done a back box with no ramps, just lie under the car and get very arms, shoulders, back and neck :|
James said:I preferred paying £23.50 for a man
