Sluggish Gears
R
Rebel
Hi,
I just bought my third K10, and I have a little problem with the gears..
It´s quite hard to shift gears from time to time... (Manual Transmission)
I´ve changed the oil, but it is still sluggish to shift gears...
Suggestions, anyone?
///Michael, Sweden
You think it´s that bad...?
The car is a -90 and hasn´t run more than 14000 Kilometers....:down:
Is it not a stiff gear linkage, or badly adjusted clutch?
The clutch seems ok, and I sprayed the links with WD-40 oil...
The rubber suspension to the gearshifter looks quite ugly, though... could they be the problem...?
But when I lie under the car I can push the stickshift upwards, about one inch, because of the bad rubbersuspension...
The linkage should thus hang in wrong angle towards the gearbox...
(Pardon my bad english, hope you understand what I write... :))
Write your reply...
