some say petrol, some heatgun, i think you can use anything but you need loads of time to do it. I found out when i heat it a little then use ordinary car polish a and cloth it goes quite quick, but you gotta be careful that way
right thanks for the help guy will start to work on them when it get warmer so closer to the summer hopefully i will get this car up to a high standard
Another way is to soak some tissue in petrol and lay it over the foam. Leave it for 10 minutes, rewetting with petrol as it dries. It should pick off really easily then but will need 2 or 3 10 minute soaks . Have to agree with Nex though, the warmer it is - the easier it is .
right thanks but i had a look for how much a toffee wheel is and they are about 6 quid on ebay so i will get that. might come useful some time when i am starting work on the car.
