i thought brackets could go etc
I think removing that pole under the steering column is a bad idea![]()
i,ve "replaced it" dan, with an alloy tube that runs across the full width of the car, which has removed that blade shaped bracket right by your left leg
one of the best moddss is lowering the roof,,,,,,,,
Just a thought - if you have a look at the NCAP rating for the K11 Micras (a measly 2 stars), the protection rating for your knees is really low. I imagine that bracket could have something to do with it fwn
i would of thought they address that issue tho as it would cut ya leg off![]()
Hmmm chop top micra hot rod
3.6 v8 rear wheel drive, wider track all round
Oh no I've had an idea
talk too ,,,,,,,,,,
just the roof's a big job !
lol that would be cool but sod the 3.6 go for a 5.0 then wack two effin great turbo's on it (Y)
Aparently not, I reckon that bracket does have something to do with the low rating for your knee on that side. Couldn't be anything else that I can think of off the top of my head. But there is also so much more in a car that could damage you anyway - other metal brackets behind the dashboard, the steering wheel/column, the engine pushing the entire dashboard back, etc
Old school top mounted supercharge
there are will, and some over-engineered scaffpole too (tho you may stir up a hornets nest lol :wasntme
http://www.micra.com.au/community/message.php?messageid=64865
Having watched the car in action on the track I assure there is nothing to worry about, having driven franks old car bluey I have no problems putting my life in his hands on an engineering level
