safety devices roll cage
johnmac
hi can anyone help I am building a road rally micra I have a safetydevices cage but no fitting kit so could do with some photos of either a plate kit or picks of the feet of a cage fitted
cheers
john
you will probably have the same "missfit" problems with any cage tho john, and the rally rulebook stated a (100cm sq ?/3mm thickness) minimum support plate or pod between the feet and the floor
hi frank that's true we have built rally cars since 1984 from avengers and saabs,the last 7 years I have built them at my garage in Lancaster including a 1300 micra with a sd cage all I wanted was picks of the feet and boxes so I could roughly bend the plates ready as it was 5 years since I built it I have forgot ,just on a tight time limit with the garage being busy
