I've now got time off, as I finally finished my dissertation.
Here's a mod I've been planning to do for months now.
I thought of it the last time I broke one of my rear indicator bulbs. And a while after, at work, when a rear indicator blew.
On the front it's not so bad to lose a bulb. The mirrors also face forwards so people can still see what's flashing. On the side, I did have those two LEDs built in to the reflectors, but they're gone now. Ultimately the side indicators are the least important anyway.
But for the rear, there's no redundancy, and it can actually be a bit dangerous to lose an indicator. Especially at work when I can't even use hand signals, being a panel/box van!
So in the event of rear indicator failure, I wanted to be able to switch to the foglights for signals instead.
So, I added the switches. These are Single Pole Dual Throw, so one input and two separate outputs.
While I did check for clearance from the parcel shelf, I didn't think about the rear seatbelt reels, which these catch on. So a bit of spade bending was required.
I forgot the condition of the rear of the chassis, it's quite fresh. The crashbar is quite brown, but the actual car body is looking really nice. The sunroof drains are still looking good, a mod I absolutely recommend.
In order for the lights to have two functions, and to save effort by using a common ground between them, I used a couple of diodes on each one. These were of course wrapped up later.
There's now quite a few more wires, so I had to cable tie them up a bit. I wouldn't want them to snag on something, hang there looking terrible, or melt on the exhaust.
It's not really possible to show the final product in photos, but it works now. When the switches are set to setting 1, the orange indicators function. When the switches are set to setting 2, the red foglights flash instead. Using the rear foglights will make them both switch on and stay on, regardless of anything else. So, mission successful!
While I was back here, I stuck on a light strip to the underside of the parcel shelf. Admittedly it's not the most straight, looking at it now, but that's okay, because...
...it's hidden when fitted! Even at this low angle only the wire leading to it is visible.
I'm going to buy another 6-pin plug (previous one got cancelled because of a pandemic [bruh] ). The one I put on there about 4 or 5 years ago is a bit shabby and a pain to separate anyway. Then I'll connect the light strip through the plug, so the shelf can still easily be removed. The light will be linked to the existing boot light and will use the same on/off switch.
Since I had the dremel out, I tidied up Cassie's rear bumper. It was getting late though so I stopped making noise. I'll continue with sandpaper next time.
I'll probably do a bunch of other things with my car this week with my new free time.
Sent from my F8331 using Micra Sports Club mobile app
