mine runs closed loop at idle rob, maybe a t/p/s or idle screw adjustment needed ?
I have the same issue and noddie reckons a small air leak could cause it? I know for a fact the plate covering the maf board isnt fully sealed on my TB.
a leak would have to be post/downstream of the t/b to affect the idle rob, and my stock pump was supplying SR20 injectors 10:1 a/f/r,s @ 130hp, so it wont be that
have you set the idle like it says in haynes ? if the tps is,nt set or the idle control valve is out of its perameters (ie, throttle idle screw too far out)Maybe its worth me trying to get the SR20 fuel rail sealed and fit that with the SR20 injectors and see what that does
changing the injectors mainly affects the idle and low throttle tho ehSince having the micra i havent touched the TPS or idle control valve, would it need adjusting for the turbo conversion?
it simple bleeds air past the throttle eh, so if the revs are still too high, you need to close the butterfly moreSo is the allen key a air/fuel mix adjustement screw or just allow more/less air past?
Found the air leak! Found a vacuum hose from front of inlet off!it simple bleeds air past the throttle eh, so if the revs are still too high, you need to close the butterfly more
