roll cage ST layout.
hi guys,
need helps here to get the layout which point to install a roll cage in my ST .. i want to customized it .. since this is a new regulation for joining the track here nowdays...
thanks.. regards..
JBK..
If you have your roll over hoop. Have the legs bolted/welded to where the back seat is. The corners can be at attached to your roof beam. The front legs will weld/bolt to the roof beam again. The rear legs wil attach straight to the rear strut towers.
Its usually fairly custom for a k10
I've got a sketch for my k10 somewhere I'll dig it out tonight
