RE: Road trip - New arrival March ST
Ok more latest:
Today I got a pile of sanding items from halfords. I sanded the bonnet back to bear metal which I would have had pics had the camera I had been using not been playing up. Anyway I undercoated the bonnet, allowed it to try and then sanded it back very lightly and put on the first of 3 top coats of metalic silver. After this I put on the laquer top coat. This was all done precisly to the recommended info, however again it didnt goto plan. It does nearly look spot on, however the metalic flakes in the paint are not at consistant angles, and so I will probably have another go possibly later this weekend. I think one of the major problems I am having is with how cold the garage is. The paints are not designed to be used in 4-5 deg conditions, and even with 2000 watts of halogen light/heat its not getting up much heat to help the paint set between coats. Other than the metalic being in odd directions the finish is so much better than last time. If I can crack this paint it will look very very nice indeed. Ill take a photo tomorrow.
Ed
