hi guys, i need your help!
i must change my clutch and i want to install something powerful rispect to the oem clutch ... can you help me?
the car will be turbo
ga16 flywheel and 190mm clutch are plug and play form my K11 1.3?
nothing mods?
nothing mods?
thats what baguete has mate, the centrebore is a bit bigger tho (nylon spigot ring ?)
Plug and Play, not need to do anything, just install the flywheel and clutch kit. I think that Scopez is using it also, but stock stuff, im using Fidanza 3,1Kg flywheel and XTD Stage 4 clutch kit.
Now i will use stock N15 1.4 clutch with stock flywheel on my grey Micra, in 2 days i will post something about it.
Yes, it is, i will use a spigot ring to center it as i think mine is a bit offset to one side, can damage the crank shells...
I think it's 1ML 805 903.Yo mate
Do you have the part number of that spoiler:
Thank you !
Help pleaseGuys, is possible to put a GA16DE clutch kit with stock CG13DE Micra K11 flywheel?
paul (polly) had his f/w re-drilled for a 190mm clutch assy iirc (covered in his blog no doubtGuys, is possible to put a GA16DE clutch kit with stock CG13DE Micra K11 flywheel?
