Ed Fusion Motorsport MSC Founder Official MSC Trader Nov 29, 2005 #3 Yes Omex make a rev limiter which would work. However you could only lower not raise the stock limit.
OP OP M maddog Guest Nov 29, 2005 #4 Rev How much will this cost? and will it do any harm to the engine?
Ed Fusion Motorsport MSC Founder Official MSC Trader Nov 30, 2005 #6 http://www.trackstore.co.uk/omex rev limiters.html
I Ian Ex. Club Member Nov 30, 2005 #7 RIK said: can someone explain why you would want to lower the rev limit? Click to expand... i believe they used for launch control. Means you dont need to concentrate on your revs, just the clutch work. Ian
j.a.kelly Ex. Club Member Nov 30, 2005 #8 i fink ma 1600 k11 needs a higher limit...i fink Rik will agree...theres so much power at top end of revs...and then....LIMIT...Ahhhhhhhhhh JK
