It's been a while I placed any messages here on the forum, sorry guys! The reason is my girlfriend has had some serious health problems... Also the CG13DE engine I had made is dead:grinning:
I placed CG10 pistons inside, did some headwork and placed the 773 cams inside. All running but never good. At some point the engine started to detonate. After looking why (ignition timing, etc etc..) it still got worse!
Before the engine would die I bought another standard CG13 (150 euro, with 60.000 kilometers).
I placed the 773 cams in the head, replaced the chain (because I had a new one), replaced the crankshaft pully with a CG10 one (this is MUCH less in weight!), placed a CG10 flywheel and a realy nice clutch, took an GA16DS airbox and placed it on the TB, placed a Janspeed manifold and put a bit bigger exhaustpipes under the car. Later on I put some Denso Iridium plugs and a new set of cables/distriburor/rotor on the ignition. Because the powerband starts to feel strong at 5000 and up, I removed the rev-limiter inside the ignition so now I can rev up to 7500 rpm's! This is realy great, but hard for me to resist
Now I realy like to go to the 7500 rpm every time I drive off.
Well I must be honest and tell you this engine runs BETTER than the one I had build before! Ans this with the 9,6:1 compression!
The thing I can not do myself is a remap of the ECU. I know Ed from Fusion makes these remaps, but I can not come to him so he can look what to do. Also I have got NATS on my car, and I don't know if that's a problem.
The truth is I would like to know if it will be worth all the money. What will I gain with this remap?
gr Chrismo
gr Chrismo
