Andy_S said:
WTF lol
Andy_S said:
kristian said:they have a black one... less powerfull than the red top
antony_aiken said:as far as i know the ford duratech is only available in the newest mondeo...
NISMO_ALMERA said:As I said before, so what if the engine makes the car handle badly...what you lose in the corners, you make up in the straights...
'Little Bandit' at Knockhill was a prime example of this!
antony_aiken said:try putting a rover v8 in a mini and you sill see what he means by Too heavy...
there would be sooo much weight over the front end everytime you lifted off the weight transfer would just throw the back end out arround every corner....
deffo an ally block
GPGP said:I am just wondering if anybody has had the balls to try and put the powerful 16v vauxhall redtop in a mark 2 micra. They are available off ebay at around the £300 mark and it would give the car about 180Bhp/ton + 185lbs/ton.
Questions:
1) What parts would be needed apart from engine? Eg new driveshafts, suspension etc.
2) Would it fit with a bigger radiator? A bit of welding needed!!!
3) Has anybody tried this before with any other engines, apart from a 1.3?
Just imagine the look on boy racers faces when a supposedly 1L micra kicks their ass!!!
