Yeah was gonna use a impact drive but we don't have one. Looks like its the hammer and chisel option. Thanksimpact driver or hammer and chisel![]()
Could it be the engine has just been sat around awhile?Looks like oil changes weren't regular
what oil changes ?Looks like oil changes weren't regular
You could probably cut the oil in half to count the rings see how old it iswhat oil changes ?
Blimey no winder why you don't have money to complete projects.... You spent it all in oil and filters haha
Beautiful that Karl
Until its started and covered in oilNice, just needs a clear perspex rocker cover![]()
Until its started and covered in oil![]()
That's okaySorry Scott![]()
ThanksIt's easier than you think Scott, just make sure you label and take photos for reference![]()
Yeah everything is just black inside! Whats best to clean all the dirt off with? Brake and clutch cleaner and tooth brush? I'll give it some love but it will get thrashed when its back in the car hahaDefinitely lack of servicing there then. I'm sure you'll give this engine the love it needs![]()
Yeah everything is just black inside! Whats best to clean all the dirt off with? Brake and clutch cleaner and tooth brush? I'll give it some love but it will get thrashed when its back in the car haha.
@ £1.35 a litreI normally just use fresh petrol to be honest, let it sit for a while then get stuck in with a stiff brush
@ £1.35 a litre... madness
I just nicked a load of cans of brake and clutch cleaner from work = free![]()
Dish washer![]()
I just remembered a trick we used to do on the tssc forum, get one of those oven rack cleaning kits with the oven cleaner and bag. As long as there are no bronze parts fitted to the head, put it in the bag with the cleaner overnight and then in the morning you hose it off and the dirt and grime just glides off. This was done with cast iron heads mind, you should check that it is aluminium safe. It's like 6 quid iirc, and almost zero effort. Chemical dip on the cheap hehedont have one unfortunately
you dont get a lot of wear on the bores or pistons scott, most of my spare engines still have the factory honing marks, but the rings will probably be worn at that milageGot a question, would it be better to swap the crank, rods and cams into the 1l engine or swap just swap the 1l pistons into the 1.3 engine? Just thinking about the bores of the engines. My 1l has done 132k miles now so the pistons are going to be worn to the same as cylinder bores so if I put them into the 1.3 cylinder bores they won't be worn the same way
Thanks frank, also I can't budge the cams out the journel closet to the sprocket. The other ends lift off a bityou dont get a lot of wear on the bores or pistons scott, most of my spare engines still have the factory honing marks, but the rings will probably be worn at that milage
have you tried turning them with a 22mm scott ?Thanks frank, also I can't budge the cams out the journel closet to the sprocket. The other ends lift off a bit
Got them out with some mile grips hahahave you tried turning them with a 22mm scott ?
could be worse
