Rear light cluster finally tinted!
After a lot of screaming and tantrums of getting bubbles out I've finally tinted my rear lights! (With the help of my boyfriend obviously!)
I've always wanted to do mine, how did you do it? Some kind of film I presume?
I'll find the link for you, it's a smoked wrap, just remove the light by the two screws and give it a good tug.. Then you trace around it cut it out peel the back off and stick on but it took me a few attempts as it's like bubble heaven at first!
Edit -
Here's the link.. http://m.ebay.co.uk/itm/190492098123
Brill, cheers Rosie. I'll get some ordered, did you use heat when you installed it?
Welcome! :) and nope no heat used I just gently laid it on then as I was pressing it down I was pushing the bubbles out just be patient with it that's the only trick really!
