Just read trough this ancient thread and seeing that cut, would it be possible/safe to put a plate on each face and then use bolts to hold it, meaning you could put different shims between to give any degree of toe/camber desired? Wouldnt mind some camber on mine see... as the front is on 2+deg already.
