Hey all,
I'm a few months away from actually starting this project but my mind has been on it a lot lately, a lot of plans and ideas and thought I might as well get some ideas from you lot before I go ahead.
Goal:
Rat Rod inspired, covered in rust, slammed with modern 'stance'. MAD MAX inspiration - lots of little details that tell story - practicality, up-cycling, lots of welding. I love details in something where you see it and go, 'ooh that's what that's for!' In film, details tell stories, they contribute to the main story in some way or tell something about the relative character. If you haven't seen MAD MAX fury road, hopefully you'll get what I mean... I've already got a backyard job roof rack made from steel rebar and others, which is rusting out real nicely. This project will not be about achieving power etc. 95% of these mods will be aesthetic. The main challenge here is to achieve the look without doing anything unsafe or illegal, which can be a big challenge sometimes.
here is the result of using the Dulux Rust Effect paint on the rear quarter - looks nice, but very flat - no drippage or inconsistencies which is the only thing I am not a fan of, but I'm thinking there should be a way of making some drippage using potentially some dust which comes from skimming brakes (Back when I used to work as a mechanic, we'd skim brakes and the dust would end up on the floor. within minutes, if there was water on the floor as well, the dust would turn into rust, as you can imagine is the same as when you wash your car and get water on your brake discs and start to develop rust just minutes after)
WHEELS:
So as we all know, there aren't as many options in 4x100 as others, especially in 13 and 14", and on top of that, NZ being a small island at the bottom of the pacific ocean, we don't have as much available as the rest of the world. So I am going with banded steelies.
The plan is to get the car on stands, take the SPRINGS out of the car, put a shock back in, put a wheel back on the hub, stick a jack under it and lift it up until I am happy with where the wheel sits, then I will measure how much of a drop that will be, and at the same time measure how much band I'll add to the steel wheel.
I'm looking for a way to make some BABY MOON HUBCAPS, if you don't know what those are, they are the chrome domes that are normally found on VW Combie vans. Thinking stainless steel mixing bowls from the local shops and fixed on to the wheel with some sort of clips...
WHEELS & TYRES
I was contemplating on 13 or 14 inch banded steelies, but based on the photos I've seen, I think I'm more a fan of 13". The goal is to be 100mm off the ground at the sills, and the idea is that 13s with maybe 155/55's will do the trick whilst keeping a decent amount of clearance at the front arches. (If you have photos of wide wheels with extreme low please comment!) We're not allowed to have stretch in NZ but I'm willing to risk having a little bit of stretch. Planning to paint the steelies some playful colour like baby blue or purple... or potentially a glossy brown with some sparkle... still not sure how wide the steel wheels will go, but I'm keen on stagger... slightly wider rear - the factory wheels seem to stick further in at the back.
Goal:
WHEELS:
WHEELS & TYRES
