Hi, try 3537 or 1537.....Hi There! Is it possible to generate the radio code for nissan micra 2004, PN7643349318, BP334936381448
MANY THANKS
Hi, try 5769 or 1769..........Hello there! Could someone generate me a radio code? The numbers I have: BP334958124420; 7643349318;
Your help would be greatly appreciated!
You are a lifesaver. Thank you!Hi, try 5769 or 1769..........
Hi, try 9848 or 1848........Hi There!
Please kindly help me with my Nissan Micra Radio Code.
Serial number - BP334936377134
PART NUMBER - 7643349318
Many Thanks
THIS video seems to suggest that it is a variation of the 'Wait 1 Hour' message and can be cleared the same way.....Hi there,
I have my radio security code, but the radio turns on with ID ERROR then starts blinking and doesn't give me an option to put the code in anywhere.
I left it running for over an hour in ACC yesterday and still just goes to the ID ERROR. It will show, then it goes to the radio and blinks but everything still works.THIS video seems to suggest that it is a variation of the 'Wait 1 Hour' message and can be cleared the same way.....
New one on me....... As you have the code the next thing I would try would be the old 'turn it off and turn it on again'. If you have access to the back of the radio disconnect all leads for a few minutes, or if not disconnect the car battery for a few minutes (either way with the radio turned ON to make sure any internal capacitors discharge).....I left it running for over an hour in ACC yesterday and still just goes to the ID ERROR. It will show, then it goes to the radio and blinks but everything still works.
Hi, how I can find that BP number?Hi @Kaneus, try 5169 or 1169![]()
You have to remove the radio from the dash, it will either be on a label on the back or engraved on the side and/or the back of it, depending on the model....Hi, how I can find that BP number?
Is there any way for you to tel me the code without BP number, because I can't disassemble inner board for number onlyYou have to remove the radio from the dash, it will either be on a label on the back or engraved on the side and/or the back of it, depending on the model....
No, the number is the key to the code.....Everybody else, who has posted on here for a code, has managed to remove the unit to get it, hardly rocket science....Is there any way for you to tel me the code without BP number, because I can't disassemble inner board for number only![]()
Just seen this, .(so yes you probably did post in the wrong threadsAnd if one of you guys could help me with a code I would appreciate it... bought my first micra and decided to fit a new battery... stupid move not to put another power supply on....
I did post this number on another tread... but most likly the wrong tread thanks in advance if you can help
BP538461724788 I have a replacement sony but the original has cool white buttons that match the interior![]()
Its been a while since I been on forums so I'm a lil rusty... thanks for the codes your a gentJust seen this, .(so yes you probably did post in the wrong threads)....... No problems, try 7903 or 1903....
My BP is 334936368446No, the number is the key to the code.....Everybody else, who has posted on here for a code, has managed to remove the unit to get it, hardly rocket science....
And the unlock code for this one is ether 5901 or 1901 (or possibly both will work?).....My BP is 334936368446
5901 is right, thank you very muchAnd the unlock code for this one is ether 5901 or 1901 (or possibly both will work?).....
Struggle no more, 1744 should work.......Hi,
I am struggling to find radio code for my Nissan Micra 2003... The details are below....
S/N BP334936355804
7643349318
Many thanks in advance
thank you so much, you deserve a treat, cheersStruggle no more, 1744 should work.......
Hi, try 4105 or 0105.....Could someone please help me with my radio code.
BP 738387811492
7647383318
Hi Claire, try 4979 or 0979......... Incidently no more codes for a few hours as I'm off to watch an afternoons Rugby on BT Sport....Hi please can someone help me with the radio code for the below. Thank you!
BP538769673560
7645387318
Hi Claire, try 4979 or 0979......... Incidently no more codes for a few hours as I'm off to watch an afternoons Rugby on BT Sport....![]()
Hi, try 6260 or 0260....Hi, could you please help me with radio. Need code after battery went flat in my micra.
BP334958131624
7643349318
Thanks,
Brilliant. 6260 worked. Thanks very much.Hi, try 6260 or 0260....
Hi, try 5873 or 1873......Hello, I swapped my battery for a new one and the radio now asks for the code (a classic one judging from this thread!). Can you please help me out?
BP538769675837
7645387318
Many thanks
Hi, try 2480 or 0480......and incidentally three separate requests on different threads in quick succession wasn't necessary, I saw the first one, the fact that I wasted time reading the other two slowed down my response.....Hi, I’ve recently bought a 2005 Nissan Micra as my first car and a code is needed to unlock the radio
BP436258405633
That is the serial number
Any help will be much appreciated
Hi, I have this exact same problem. After changing battery, no opportunity to enter my codes, goes to ID error. Have tried leaving it in acc position for over an hour, tried on position for over an hour and running for over an hour, no luck. Have disconnected battery with radio on and left for 10 minutes. Still shows ID error. Couldn’t find if OP had success or not. Any idea what to try now?New one on me....... As you have the code the next thing I would try would be the old 'turn it off and turn it on again'. If you have access to the back of the radio disconnect all leads for a few minutes, or if not disconnect the car battery for a few minutes (either way with the radio turned ON to make sure any internal capacitors discharge).....
I forgot to add that just like the OP my Nissan radio/mp3 audio system works fine except the display flashes. I can disconnect the battery with the need to enter radio code when reconnecting. Just need to reprogram stations. It seems the anti theft is not working. I’d just like to stop the flashing.Hi, I have this exact same problem. After changing battery, no opportunity to enter my codes, goes to ID error. Have tried leaving it in acc position for over an hour, tried on position for over an hour and running for over an hour, no luck. Have disconnected battery with radio on and left for 10 minutes. Still shows ID error. Couldn’t find if OP had success or not. Any idea what to try now?
