Hi, try 4527 or 0527....Hi all looking for the unlock code for my wife’s micra.
Bp334958138505
7643349318
Any help is greatly appreciated.
Bp334958138505
7643349318
4527 was the one. Thank you.Hi, try 4527 or 0527....
Strange, the only ones that I haven't had success with before are the much later sat-nav models that start BP000.
When you say it 'doesn't work' do you get 'wrong code' or is the number just not inputting when you press the code enter button? If the latter try pressing other buttons to accept the entered code..
Try the arrow up button on the right hand white knob, if that doesn't work try all of the other possible buttons except the number buttons and the power button, one of them will input the code.View attachment 57985
That´s, exactly that is what has happened.
When I try input the code and I press the enter button AF, or TA key, don´t accept the entered code.
edit:- just had a quick look on the internet and I was right , see HERE
Hi, try 9397 or 1397Hi, same problem here, please please help
BP5384 6 3843377
7 645 384 318
Grateful already
Hi, it would appear that the magic number for your radio is 1108.....Hi,please help!
BP334947266660
8 635 123 392
Sorry don't recognise any of those numbers, doesn't look, from those, that it is a BlauPunkt unit that I can decode.....Hello,
Hoping you can help me get the music back in my life!
serial # 3135349
device #7612830023
9811 would appear to be said 'magic number', but in the unlikely event that it isn't then try 1811To the legends that are helping to bring back the music...
Please could you provide me the magic number..for the following Nissan radio
BP538753302222
7645387318
Your help would be greatly appreciated..
You sir are a Gentleman and a Scholar.9811 would appear to be said 'magic number', but in the unlikely event that it isn't then try 1811
Hi, try 4183 or 0183.........Hi! Can you help me with the code for my Nissan radio?
My serial number is BP234632014582
Part number 7642346318
Thank you in advance!
Hi, try 5356 or 1356.....Hi, just got K12 2007 in mint condition.
Could you please help to unlock radio?
BP5384 671 85429
7645384318
Great! First one worked. Thanks!Hi, try 5356 or 1356.....
I assume that this is a SatNav unit in a K13? Sadly my software will not decode any BlauPunkt units starting with '000'Hello
Can you please help to unlcock radio for Micra 2009?
BP0003 9 5299719
7 612 830 003
I assume that this is a SatNav unit in a K13? Sadly my software will not decode any BlauPunkt units starting with '000'![]()
Hi, try 6801 or 0801.....hello need code to my micra please
code for MMR CD-G
BP 5384 6 3845461
7 645 384 318
Hi, try 8150 or 0150......Hello! I need code to my micra
The model is BP3349 4 7317827
7 643 349 318
Hi try 5670 or 1670........Hello, does anybody have the radio code for BP334936346802 serial no 7643349318!
It’ll be massively appreciated!
Thank you so much! I will try in the morning ?Hi try 5670 or 1670........
Hi, try 4014 or 0014.....Hello John_D, can you help to me as well with my radio code. The serial number is BP538464180709. Thank you.
4014 works just fine. thank you very much for quick answer.Hi, try 4014 or 0014.....
Hi, try 2191 or 0191........Hi! I need some help with my radio code for my Micra K12. Can you help me, John_D?
BP234746063394 is the serial number.
Many thanks!
Thank you, John!Hi, try 2191 or 0191........
Hi, try 4369 or 0369....i have the same problem
need the code to unlock the radio on my nissan micra of 2003
BP234631985343 this is my serial number
Could you help me?
Perfect, thank you JohnHi, try 4369 or 0369....
Hi, no problems, try 9369 or 1369 and the unit is actually made by BlauPunkt. The logo on the front appears to depict two overlapping stylised CDs, (the 'CO') and the 'R.D.S' part stands for 'Radio Digital System' which means that on FM you get extra data displayed, such as station identity...)Hi, hope I’m in right place and apologies if not. Looking for some help with 2nd hand Micra c+c, just purchased, regarding radio code.
Only numbers I can find on the unit are:
BP538753303374
LP 8 635 123 6153
66 70000 2597 Nissan MMR IDC-G
Radio make is COR.D.S
I would appreciate some help if possible and many thanks in advance.
Something wrong with those numbers, I need a part number, starting with 'BP' followed by twelve numbers, (sometimes a letter in place of the fifth number) to generate the code........My daughters nissan micra 2009 plate car battery was dead from parked idle for too long so I took off the negative terminal to recharge it and now the cd radio ask for a pin code :-(
On the top of the radio cover its says BP - Nr. 7 612 830 003
Nissan Part No 25915BH00D
Any ideas ?
Hi 2840 or 0840 should unlock it......hi good day
please i have problem in my car battery so i chang it ( it was a problem in radio it self changer problem taks al the power jam in cd ) it was no needed to chang battery
can you help with radio code i remove it ...
my serials
Bp538771223339
7645387318
thankyou v much
Hi, just one possible for this...0570.......Hi all, could some kind person please help me with my radio code? BP538469493743. thanks in advance
You sir are a legend. Thanks!Hi, just one possible for this...0570.......
