pork Club Member Aug 30, 2016 #1 Can someone confirm which wire is what? Using my own ecu and loom, and having a couple of issues, so just checking my wiring Sent from my iPhone using Tapatalk
frank Club Member Aug 30, 2016 #2 green/white tends to be 12v neil, and white signal, is the other one black ? (earth)
OP OP pork Club Member Aug 30, 2016 #3 I've got it wired up 12v-earth- signal Might be the problem then. I keep blowing the coil fuses as soon as I power up the ecu , but only when I plug in cylinders 3 and 4. The coils are paired up inside the ecu Sent from my iPhone using Tapatalk
OP OP pork Club Member Aug 30, 2016 #5 That's how they are in the ecu, 1 is parralell to 3 2 is parralell to 4 but I guess it's down to where you distribute the wire to whatever cylinder. Sent from my iPhone using Tapatalk
OP OP pork Club Member Aug 30, 2016 #6 Ecu can do up to 12 cylinders, with each driver power ring multiple coils....apparently Sent from my iPhone using Tapatalk
OP OP pork Club Member Aug 30, 2016 #8 Cylinder 3 and 4 I get continuity to ground constantly With probes in the live and on block But if I've wired the plugs up wrong, that'll explain it Sent from my iPhone using Tapatalk
