I don't pretend to be an expert on ignition systems, far from it. But to me it sounds like its doing what you coil pack or capacitive discharge thingy is already doing, storing energy and then releasing it in one go to make a spark. What's changed?
Edit: Reading on a bit, they do make a convincing case as such, but I don't know enough to make any sort of statement, true or false!
i,m pretty sceptical :suspect:, there,s only so much energy stored in a charge of fuel/air, and when it,s burned it,s burned.
manufacturers have tried twin sparkplugs for instance, then dropped the idea fwn
I hadn't heard of them till recently and i suppose if they had been any good you would have seen them more often.
Saying that K&N for example make very little change but you see them every where.
The bit i was not sure on, were the cars they have tested them on i.e Evo, golf turbo all seen good gains but no more gains then you could get potentially from a decent setup.
