Morning gents. Me and my dad are building some pulse jet engines because we both wanted a cheap exciting hobby that gives us a break from cars and tractors.
Here is the ignition system that we have made. Iam waiting for stainless sheet. stainless mig wire and gas.
Eventually we may end up with a pulse jet hovercraft but I gotta learn how they work properly first
Now I fully understand there are probably many easier options that I could choose, but being from an automotive background I decided too use a points ignition distributor, ballast resistor and coil. This is all powered by a battery drill. I think ill swap the drill for an electric screwdriver! The screwdriver runs at 140rpm which should give me 8ish sparks per second.
Is 8 sparks per second adequate?
It's still in mock up mode at the mo, mostly bodged for testing!
https://www.youtube.com/watch?v=Tc_HYWc8fZA&feature=youtube_gdata_player
That isn't flat out in the video and I would expect a healthier spark once the wiring is completed properly.
I have also had a go at triangle injectors like grims thread, look pretty good but no pics.
