Not really an update, but here is one non-the-less.
The Micra will be coming off the road within the month, due to too many niggly little/ big problems that I should really sort out but due to my wish coming true having more hours in work, I no longer have the time to sort them out. PLUS imo, with it been off the road, I have the time to do the jobs properly.
My new addition will be getting an eZX interior, electric windows, coilovers and a decent sound system, that is it. Plans for the Micra whilst off the road
Grab a cuppa, this is all the plans that will be happening. I plan to get the car back on the road for Japfest or JAE 2014.
Engine:
CG13DE
Lightweight pulleys (if the GB comences)
Lightweight flywheel
1.3 gearbox with Quaife LSD
I have enquired with ASP about making a signature edition spec manifold for the CG series (normally for FWD SR20s)
Tomei Poncams with ajustable gears and better valve springs (will e-mail Brian Crower)
Toyota Glanze 4E-FE inlet manifold with a Apex-i cone filter with a custom CAI
Nistune ECU.
Nismo mounts
Suspension/ Handling:
BC coilovers
Cusco 4 point lower brace
Nismo upper strut brace
Custom B pillar brace
Custom C pillar brace
Rear strut brace
Nismo Panyard Rod
Nismo ARB's
Seam weld engine bay
Interior:
OEM Black interior trims
Nismo 330F steering wheel NOW GOT
Nismo/ SLX clocks/ dials mixed together to have digital clock, white faces, MPH gauge and all those warning lights (which will all work)
Dial surround with 3 switches
folding mirrors
Headlight adjustment
Power Steering
Air Conditioning possibly climate control if I can find a breaker unit on Yahoo Auctions
Modify the dash pod to have a little light in the storage compartment
Refigirated glovebox
Series IIII door cards with cup holders in the door pockets, modify arm rest to go right to the end of the door
Vibration/ Sound deadener in doors
Electric windows
JDM flare holder (will source flare)
Heated seat lower centre console panel
Cruise Control
Recaro front seats with heat pads
P1 SLX rear seats with headrests, trimmed to match recro's, heated, with the switches moulded into rear super S trims
Sound deaden behind trims and roof
Non-smokers ashtray
Electric Pop out rear windows (motor from a people carrier, switch will be in 3rd location on the clock surround trim)
JDM map light with heater/fan for rear passangers
March sill kick plates
Boot plastic trim surround
Armrest from a convertable March
boot/fuel cap opening mech
Sun visors with mirrors in them
Brakes:
OEM disk brake rear axle
Mitsubishi FTO 4 pot fronts
Braided brake lines (make I am yet to decide on)
ABS (I am going to this extent, yes)
Standard brake pads
Asthetics:
Rainguards
Nismo rear spoiler
Nismo Grille
Nismo front splitter
Nismo rear splitter
Nismo side spats
Colour coded door handles
Colour coded wing mirrors (bases to stay black)
8% bronze tint in windows
JDM number plate recess
16VALVE sticker on rear window
LED rear lights
Nismo graphics (like what you find on the 350's n ****)
Apexi N1 exhaust system
SR front mudflaps
Rota Grid Drift 16x8 with slim profile Toyo's
Most importantly:
New genuine crossmember
Fully treat underneath with any welding or anything else rust related problems needed
You may laugh, but this will happen, have a few bits ready... getting an iphone before any of this happens haha.
This will be the last update until photo's of it's last drive as a pretty standard car.
Ta.
