Primera P10 Fault Code 21
any idea how to sort that out as its a rnn14 ecu and a p10 dizzy
heh, i thought so :) the optical disc is probably different mate, some have 36 slits and some have 2 sets of slits and 2 sensors iirc.
have a look under the caps and compare them eh
spoke to D Bull and he says i have to swap fuel pump relay pins 104 and 106 and the crank sensor pins any idea what pins they would be?
the ecu pins eh glen, either pull them out the connector and swap them, or cut-n-shut the wires if they are present i guess
codes 21 and 11 are dizzy related tho eh glen, how come you have a spark but no fuel being injected ? (it sounds nats like)
